1998 Ford ZX2 Coupe Vent Control
1998 FORD
SMCNERNEY
My vent control is stuck on defrost which I know to be a vaccuum leak (as I know the mechanicals are all conected). Where in the engine compartment do I look for the leak?
Mar 13, 2007 at 6:57 AM
2CARPRO JACK
  • 11,533 POSTS
Usually the source line goes through the firewall near the heater and a/c lines. Will be a small black plastic line,usually has a check valve on it somewhere and might even go to a vacuum resevoir (small plastic bottle)
Mar 14, 2007 at 12:54 AM
SMCNERNEY
Thank you! I found the disconected hose and it all works now!
Mar 14, 2007 at 5:19 AM
