1997 Other Ford Models Cruise Control
1997 FORD
75,000 MILES • V8 • 2WD • AUTOMATIC
DUSTYSRV
I have a '97 Dolphin motor home with a Ford 460 engine and automatic transmission and cruise control. Is there some way to convert the cruise control to just a throttle control? The problem is; when I am driving in cruise control and approach a hill I have to remember to kick out the cc in order to prevent the engine from slamming from 2500 rpm's to 3700 rpm's in a blink when the over-drive kicks out automatically. Usually I can anticipate when that might happen, but sometimes the incline is so gradual that the accelerator pedal is fully depressed before I realize it. I think a throttle control would be easier on the engine and tranny and on fuel consumption.
Nov 22, 2009 at 5:34 PM
MIKE H R
  • 3,094 POSTS
On the cruise control there are two wires that go to the downshift control. There should be a blue one with a white stripe and a green wire. Disconnect the blue one and that should keep the transmission from downshifting when the cruise is engaged.
Oct 3, 2010 at 2:28 PM
