1997 Other Ford Models car heating system
1997 FORD
MJHODGSON5481
Heater problem
1997 Other Ford Models Engine Size unknown Wheel Drive Type unknown Manual 10700 miles
i have a ford ka s reg the heating inside is giving out cold air and not heating up at all inside could you please tell me what you think it is
Jan 2, 2008 at 6:20 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9492d923d6="mjhodgson5481"]Heater problem
i have a ford ka s reg the heating inside is giving out cold air and not heating up at all inside could you please tell me what you think it is[/quote:9492d923d6]
Is the car temp OK and at normal operating temp
if not start by replacing THERMOSTAT
if OK check heater core hoses under the hood two hoses should be hot
is not you need to pull them out and flush heater core by running water and compressed air throw one out the other and vise versa
if hot its the blend door under dash you need to check
GOOD LUCK
Jan 5, 2008 at 1:41 PM
