1997 Honda Accord LX
1997 FORD
MS MAY
I have a 1997 Honda Accord LX. The drivers side window is stuck in the down position. The switch will not work. The other window switches work fine. I am female and cannot afford to get it fixed. I also cannot drive anywhere with it open for theft.
1. Where can I get an electrical system schematic for this?
2. Is this something i can do myself or is it very difficult? I have no experience whatsoever.
Feb 12, 2006 at 1:00 AM
FLIPZ
  • 5 POSTS
I have the same problem with my 1997 honda accord LX. The window will go Down, But won't go back up, I read on a different sight to try pouring rubbing alcohol on the switch and working it back and forth to clean up the connection. If that doesn't work try using a switch from one of the other doors, and see if you just need a new switch, you'll have to take the door panel off. I'll try it myself and tell you how it works out.
Feb 12, 2006 at 11:46 AM
FLIPZ
  • 5 POSTS
I took out the switch, cleaned it up, poured rubbing alchohal on it and worked the switch back and forth, I hooked it all back up and now my window is working fine.
Feb 22, 2006 at 4:28 AM
