1996 Other Ford Models BATTERY DRIANAGE
1996 FORD
95,000 MILES • 4 CYL • 2WD • MANUAL
BIGHILL1959
REPLACED BATTERY ON FIESTA DIESEL 1800cc
replaced startrer motor but battery drained in four hours can you suggest what to do
Jan 20, 2008 at 12:14 AM
MIKE H R
  • 3,094 POSTS
Had you had battery problems before you replaced the starter? If so you can have the altinator checked. it can be done at most any auto part stores. also ask to check the battery drain when the engine is off
Jan 20, 2008 at 3:41 AM
