1996 Other Ford Models
1996 FORD
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
TAUWHEA
How do you change the transmission oil
Jan 6, 2008 at 3:54 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
Some transmissions have a drain plug, others have to have the pan removed, If you remove the pan, replace the pan gasket and filter element, re fill with approved oil for your transmission and check the level is correct when hot as per your cars instructions, check for leaks., when finished.
Mark (mhpautos)
Jan 6, 2008 at 4:08 AM
