What I was simply doing was some diagnostic routines, making sure the wires were not shorted before the switch or after the switch by having you disable it and also find out how long it runs untill the fuse blows.
I have to ask questions unless you want me to just make wild guesses at what to replace.
You can either replace your compressor as it is going bad drawing too much amperage. Or you can replace it with a circuit breaker and it will pop instead of blowing fuse then turn back on in a few seconds til the motor causes it to blow again.
Id ask another question to make sure thats the problem but sounds like you just want parts.
So if that doesnt work replace your lines and solenoids on the suspension
Wednesday, October 20th, 2010 AT 9:45 PM
