1995 Other Ford Models oil pump replacement
1995 FORD
LBGOOD
Engine Mechanical problem
1995 Other Ford Models V8 Two Wheel Drive Automatic
I need to know if i can drop the oil pan to be able to get thew oil pump that needs replacing
Feb 24, 2010 at 4:23 PM
MICKEY-D
  • CAR REPAIR CONTRIBUTOR
  • 304 POSTS
You should purchase a repair manual for your car, it will explain the steps and probably what tools you'll need. A lot depends on the model because you may have a crossmember or steering components in the way.
.......................mickey-d
Mar 2, 2010 at 10:48 AM
