1994 Other Ford Models tps sensor
1994 FORD
135,000 MILES • V8 • 2WD • AUTOMATIC
ABRAHAN QUINTANILLA
How can I change the TPS sensor in my ford ecoline club wagen 1994.
Mar 4, 2009 at 11:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Disconnect the TP sensor wiring harness.
On 5.0L and 5.8L engines, it may be necessary to remove the throttle body. On all other engines, proceed to the next step.
Disconnect the wiring from the sensor.
Matchmark the TP sensor and throttle body. Remove the 2 retaining screws and the sensor.
INSTALLATION:
Slide the rotary tangs into position over the throttle shaft blade, then rotate the TP sensor CLOCKWISE only to the installed position. Failure to follow this step may result in high idle speeds for 5.0L and 5.8L engines.
On 5.0L and 5.8L engines, position the TP sensor so that the pigtail points toward the IAC valve.
Secure the TP sensor to the throttle body with the retaining screws. Tighten to 18-27 inch lbs. (2-3 Nm) on 4.9L engines or 11-16 inch lbs. (1.2-1.8 Nm) on 5.0L/5.8L engines.
If applicable, install the throttle body.
Connect the wiring.
Connect the negative battery cable.
Thanks for using 2CarPros.com!
Mar 4, 2009 at 5:14 PM
