Engine Mechanical problem
1993 Other Ford Models V8 Two Wheel Drive Automatic 154k miles
The vehicle is a '93 Ford Clubwagon E350. Just after it warms up, the oil pressure drops off significantly. The needle burys below the low pressure line. As this happens, there is an increasingly loud rattling sound. Is the sound coming from the push rods and does this indicate that the oil pump is bad?
Thank you for your help.
May 1, 2008 at 6:47 AM
