1993 Other Ford Models LEAKING OF PETROL FROM MUFFLERS???
1993 FORD
230 MILES • 4 CYL • 2WD • MANUAL
MALEK73
HI THERE I HAVE THIS MAJOR PROBLEM WITH MY FORD COURIER 1993 UTE 2.6 LT IT IS LEAKING PETROL FROM THE MUFFLERS THE TOP OF THEM THAT IS STUCK TO THE TOP OF THE MOTOR I CHANGED THE INGECTIONS AND CHANHGED THE HEAD GASKETS ALL NEW BUT I AM STILL HAVING THIS PROBLEM WHAT WOULD BE IT BE????? PLZ HELP THANKS FOR TAKING THE TIME TO READ AND HELP ME !!! WAITING FOR THIS REPLY VERY BADLY THANKS AGAIN....
Oct 11, 2009 at 9:32 PM
Hi there malek73 and TY for the donation this is what keeps the site going
Check all the injectors if they are leaking and also the fuel pressure regulator disconnect the vacuum hose from the regulator if there's fuel in the hose the regulator is leaking and needs to be replace. Also check if the fuel return line is clogged-up.
Oct 11, 2009 at 9:53 PM
