1993 Other Ford Models HEAD LIGHTS
1993 FORD
MARILYN PROCTOR
1993 Other Ford Models V8 All Wheel Drive 70,000 miles
WE BOUGHT A RV FLEETWOOD SOUTHWIND AND THE HEADLIGHTS ARE VERY DIM EVEN ON HIGH BEAM. MY HUSBAND IS CHECKING THE CHROME PAINT INSIDE THE LIGHTS NOW. WE HAVE GLASS LENS AND THEY LOOK FINE. ANY SUGGESTIONS
Apr 15, 2009 at 4:10 PM
MIKE H R
  • 3,094 POSTS
if the headlights get dim or are they dim all the time. If they get dim then I would check the charging system. If they are just low, I would check the connections. make sure there is a good ground from the chassis to the frame. Does the charging indicator say when its running that it is charging? If so then a connection would be the problem. especially the ground.
Apr 17, 2009 at 8:21 AM
