1993 Other Ford Models cooling system
1993 FORD
55,000 MILES • 4 CYL • FWD • MANUAL
SA BLUEMOONER
my wifes ford lazer is over heating i can,t see any leaks on the pipes & there is no water in the oil could it be the thermostat or an air lock look forward to your advice thanks Arthur
Apr 17, 2009 at 11:25 PM
  • 75,988 POSTS
Cooling fans are they coming on?
Try replacing the thermostat for a start and bleed the cooling system both don't work. Check for a clogged up radiator and a defective water pump.
Water pump, radiator, thermostat, cooling fans okay Get it block and pressure tested to rule out a blown headgasket cracked head or block
Apr 17, 2009 at 11:57 PM
