1992 Other Ford Models Gunk in the rocker cover
1992 FORD
OZQBA
Engine Mechanical problem
1992 Other Ford Fiesta Manual 90000 miles
I am experiencing greese or something like it in the rocker cover which is starting to clog my carb. I have cleaned the head and pistons thoroughly replaced the oil and oil filter as well as the air filter. But it still appears to be doing this. I can see no fuel filter to change. So does anyone have any suggestions. A complete engine change is not an option.
Cheers,
Mar 17, 2008 at 2:21 AM
LEGITIMATE007
  • 5,121 POSTS
check you pcv valve if thats bad then you will get a build up
Mar 17, 2008 at 2:26 AM
