1992 Other Ford Models changing a water pump
1992 FORD
150,000 MILES • 4 CYL • FWD • AUTOMATIC
GARYRG
I need to chane the water pump in my car and just need a little info before i get started i have never changed awater pump on a front wheel driver car before any tips would be great and a picture or two would also go a long way thanks
Mar 15, 2008 at 10:32 AM
  • 31,937 POSTS
You may have to check some of the engine management sensors, i would be looking at the air flow meter, these can be a problem. what they do is give a fauls readig to the ECU, as it is still giving an input signal(albeit faulty) the ECU will not log it as a fault.
Try here first.
Mark (mhpautos)
Apr 2, 2008 at 9:37 PM
