1991 Other Ford Models catalytic converter
1991 FORD
REYMYSTRIO7
1991 Other Ford Models 4 cyl Manual
when we drive it, the catalytic converter turns red and we changed it because the old was bad, but when we tested drive it, it still turning red what might be the causes of that? what else may be the problem?
Apr 25, 2008 at 3:46 PM
  • 75,988 POSTS
The engine is running way too rich and the excess fuel is being combusted in the Cat this can be caused by an exhaust leak, the leak will cause the air/fuel mixture to become rich, the extra fuel can't be used by the engine so it puts it into the exhaust system the extra air pulled in from the exhaust leak and the heat creates the combustion of fuel in the Cat. The oxygen sensor sees a lean condition and commands the computer to go full rich, this combination can cause the condition you have. Test the oxygen sensor/s whether its switching properly from rich to lean and from lean to rich-
Apr 25, 2008 at 4:57 PM
