1990 Other Ford Models whee wobble
1990 FORD
SLAM61
Tires and Wheels problem
1990 Other Ford Models 4 cyl Front Wheel Drive Manual 132.00 miles
My wheels wobble at around 60-70 mph.. i have had tracking/balancing done also bull joints and track rod ends..the car drives fine until i reach thses speeds..
Mar 11, 2010 at 2:50 AM
HMAC300
  • 48,601 POSTS
this could be several things, bad tires for one, the tires could be balanced bu tif the guy is'nt paying attention it can be a bent wheel, or bad tire but still go into ballance. If you can jack each wheel upand spin it by hand you should be able to seee this. It could also be a rotor or something similar to that. Hqve the tie rods been checked, and all otherfront end compontents. a pro really needs to look at this carefully as itcould be a dangerous thing going on..
Mar 12, 2010 at 3:07 AM
