1990 Other Ford Models power steering pump
1990 FORD
71,000 MILES • V8 • 2WD • AUTOMATIC
BEN AUSTIN
how to replace the power steering pump on a econo 350 c-class motor home with 460 motor.
Nov 25, 2009 at 8:27 PM
MIKE H R
  • 3,094 POSTS
changing the power steering is just like changin one on a car. the 460 motor gives you less room to work with and you have to pull the inside engine cover off to get at the bolt in the back of the poer steering pump. The space to get the front bolt out is limited. You may have to even pull the radiator. Everything in the c-class is tight getting to without removing the insdie engine cover.
Oct 3, 2010 at 7:20 AM
