1989 Other Ford Models Tacometer Misreading
1989 FORD
15,000 MILES • 6 CYL • 4WD • MANUAL
ROB FERGUSON
My 1989 Ford Bronco II XL's tach needle will periodically swing wildly or show an excessive rpm reading. There does not seem to be a pattern to when it behaves in this manner but is a random occurence.
Is there a faulty electronic pick-up or sender unit that is causing this situation?
Your assistance is greatly appreciated.
Dec 23, 2007 at 5:47 PM
  • 75,988 POSTS
You might want to check the coil's positive and negative connections-could also be the tach itself out of calibration.
The tachometer is always hooked-up on the secondary circuit of the ignition system
Dec 23, 2007 at 6:59 PM
