1989 Other Ford Models steering
1989 FORD
277,000 MILES • 6 CYL • 2WD • AUTOMATIC
HARRYERIC
steering all over the place inch of playy at the steering wheel
May 14, 2008 at 8:36 PM
  • 31,937 POSTS
Hi there,
you better get it checked ASAP as something is about to fail big time, check that the tie rod ends are not loose and the rack is bolted up tight. I would recommend that you get a mechanic to inspect this problem before you experience total steering failure.
Mark (mhpautos)
May 14, 2008 at 10:40 PM
