1989 Other Ford Models fuel pump
1989 FORD
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRONCO2_0422
Hi, I own a 1989 ford bronco II. I ordered a new fuel pump a week ago and installed it the same week. the pump is not sending fuel at all. It turns on runs and a cycle but does not seem to pump and fuel. I disconnected and checked everything from the engine back to the fuel pump. I dont know what to do, could you guys shoot me some ideas? what is the best way to check if a fuel pump is broken or not?
Oct 11, 2010 at 10:29 AM
  • 75,988 POSTS
Hook up a fuel pressure tester and check if the fuel pump is producing fuel pressure though its new-or pull it back out and bench test it
Oct 11, 2010 at 10:48 AM
