1989 Other Ford Models Coolant leaking into oil
1989 FORD
50,000 MILES • 6 CYL • 4WD • MANUAL
BRONCO II
2.9 V6 COOLANT LEAKING INTO OIL TRYED R-R INTAKE MANIFOLD GASKET BUT PROBLEM STILL EXIST WHERE ELSE COULD THIS LEAK BE AMOUNT OF COOLANT LOSS TO OIL IS SMALL
May 24, 2009 at 12:29 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:aa0a47dfe8="Bronco II"]Engine Cooling problem
1989 Other Ford Models 6 cyl Four Wheel Drive Manual 50000 miles
2.9 V6 COOLANT LEAKING INTO OIL TRYED R-R INTAKE MANIFOLD GASKET BUT PROBLEM STILL EXIST WHERE ELSE COULD THIS LEAK BE AMOUNT OF COOLANT LOSS TO OIL IS SMALL[/quote:aa0a47dfe8]
Since you already done one of the 2 possibilities. The only other is the Head Gasket.
Since you say it is a small amount you can try adding a radiator seal.
May 24, 2009 at 1:50 PM
