1988 Other Ford Models fuel pump pressure
1988 FORD
31,000 MILES • V8 • 2WD • MANUAL
HAPPYCAMPER88
Please provide specs for fuel pressure for a Ford E 350 motorhome with a 7.5 liter engine. We are only showing 35- 40 psi and this seems to be low for a high presssure pump. We have no power uphills and seems to be dumping gas as it only got 3 mpg as we nursed it home. We installed new plugs, wires, cap, rotor, map sensor, and O2 sensor. Cat conv. ok. Have not pulled exhaust yet as pressure seems strong and unit is welded. Vacuum pressure seems to be weak. Any suggestions much appreciated.
Jul 30, 2008 at 2:35 PM
  • 75,988 POSTS
460/7.5L engine The fuel pressure is within specification 30-45psi Vacuum pressure seems to be weak: If you're refering this as vacuum better check the exhaust for excessive backpressure-either a pressure or vacuum gauge will do- EXHAUST SYSTEM BLOCKAGE: high reading when engine first started, falling back to 1 or zero and gradually increasing to 15 or 17.
https://images.2carpros.com/forum/automotive_pictures/12900_vac16_3.gif
Good Luck
Jul 30, 2008 at 3:01 PM
