1987 Other Ford Models djlaw123@yahoo.com
1987 FORD
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
LARRY62882
  • 21 POSTS
Wanting to know if you could direct me to were i could find the engine control module wiring relay im having problems no fuses or relays was in fuse box trying to figure out were they go
Mar 29, 2010 at 9:08 AM
HMAC300
  • 48,601 POSTS
check under th hood for the ECM on one of hte fenderwells or around there. Also some of the fuse boxes are there as well.......
Mar 30, 2010 at 5:21 PM
LARRY62882
  • 21 POSTS
ok i cant find the ecm on firewall the only thing that im finding by the looks in my manual is a eec power relay is this the same thing as a ecm?
Mar 31, 2010 at 10:37 AM
HMAC300
  • 48,601 POSTS
I said FENDERWELL not firewall. It is usually called an ecm or pcm. Although eec could mean electronic engine control. I fyou can't find it go to an auto parts store and have them SHOW you what you are looking for so you will know what it looks like. I could also be hidden behind your kick panel onthe passenger side.
Mar 31, 2010 at 6:23 PM
LARRY62882
  • 21 POSTS
OK IT WAS BEHIND KICKER PANEL.REPLACED IT WITH A NEW ONE. HAVE HEADLIGHTS TAIL LIGHTS ENGINE CRANKS OVER A FEW DASH LIGHTS.STILL NO POWER TO ANYTHING ELSE LIKE FUEL PUMPS.I CHECKED ALL THE FUSES WITH TEST LIGHT STILL ONLY THE SAME ONES WORK NOT GETTING POWER TO FUSE PANEL CHECKED FOR ALL THE HOT SIDES OF THE FUSE PANEL WERE THE RELAYS PLUG IN ONLY A COUPLE HAVE POWER TO THEM.THE ONES THAT HAVE POWER TO THEM IS THE AC/TEMP SWITCH,THE SEAT BELT REMINDER,AND THE IGNITION SWITCH RELAYS.. THERE ARE 20 REGULAR FUSES AND 13 CIRCUIT PROTECTED RELAYS IN FUSE PANEL
Apr 1, 2010 at 8:31 AM
HMAC300
  • 48,601 POSTS
one thing i forgot to mention is that check the starter or starter relay you may have a fusible link by there . It will be a smaller wire connected to a larger one. It will be on the positive side.they burn out and you lose power to different things. But they are there for protection. Anyhow check those....
Apr 1, 2010 at 1:40 PM
LARRY62882
  • 21 POSTS
ok iv checked all the fuse links around the battery area changed ecm but sill no power to fuel pumps also reset fuel pump relay switch someone has cut the wires to the rest button and wired them together ty larry
Apr 2, 2010 at 6:12 AM
