I have a 1986 Ford Bronco2 with the 2.9L EFI V-6. It really has a problem pulling a hill. It lunges and jerks and I usually have to pull it down into a lower gear to get up the hill (which makes it lunge and jerk all the more). It never backfires so I don't think it's the cam. Running down flat road it runs great.
I've replaced the Air Bypass Valve, the TPS, the Fuel and Air filters, had a complete tune-up, had the timing checked, made sure there were no vacuum leaks, It's not jumping fire and the throttle body is spotless. (never a check engine light)
Does anyone have any suggestions?
May 8, 2008 at 3:37 AM
