1986 Other Ford Models carb backfire
1986 FORD
STARBAR
Engine Mechanical problem
1986 Other Ford Models 4 cyl Two Wheel Drive
hi i have a ford capri witch keeps backfireing thru the carb (twin choke webber) when u slam the revs down. when u rev it slowly its fine. ive checked the timing and put another carb on
any ideas
thanks nick
May 29, 2009 at 6:33 AM
Backfiring:
This is the popping or banging sound sometimes heard in the exhaust when decelerating. It can indicate a problem such as over-rich carburetion, a bad exhaust valve or an ignition problem (retarded timing or a cracked distributor cap). If the backfiring occurs through the carburetor, it may mean over-advanced timing, a bad intake valve or a cracked distributor cap.
Jun 4, 2009 at 11:16 AM
