1986 Other Ford Models
1986 FORD
CWS07
Engine Performance problem
1986 Other Ford Models 6 cyl Four Wheel Drive Manual
when i start it very bad black smoke and overloading bad put tune up and 02 sensor still runs very rough and wont hardly stay running have to hold peddal to the floor to run thanks
Dec 20, 2009 at 4:09 AM
HMAC300
  • 48,601 POSTS
if this has a carburetor it sounds as if the choke plate is staying closed. If not check your fuel pressure as our regulator may be bad. if you look on this site on more service repair it will explain how it works.......
Feb 6, 2010 at 12:36 PM
