1985 Other Ford Models Starting a long idle car
1985 FORD
HUBPUB
Engine Mechanical problem
1985 Other Ford Models 6 cyl Two Wheel Drive Automatic ~70,00 miles
My wifes car has been sittiing idle in a garage for 6-8 months while she was sick. I would like to start it again. What is the proceedure I should follow. I live in California
Jul 8, 2010 at 11:01 AM
HMAC300
  • 48,601 POSTS
you should be pretty safe to charge the battery and change the oil before you start it. change the oil filter as well. then start it up let it build some oil pressure up before you rev it. It should be ok, then put some fresh fuel in it if it's not full. if the tank is full runabout a half tank out and then put the fresh fuel in.
Jul 22, 2010 at 4:47 AM
