Ford E350 motorhome must pump footfeet for gas, runs @ 30 seconds then dies, also there is a fuse marked module 15 amp that keeps blowing unable to figure out which or what module
Tuesday, September 28th, 2010 AT 3:40 PM
MECHANIC
Hi there,
Thank you for the donation,
What engine is fitted and is it EFI or carby?
Mark (mhpautos)
SPONSORED LINKS
Wednesday, September 29th, 2010 AT 6:45 AM
KEVIN HARBAUGH
MEMBER
The motor is a 7.5 with a holley 4 bbl.
Wednesday, September 29th, 2010 AT 8:08 AM
MECHANIC
Hi there,
Get the carby cleaned & re set, check pump pressures & fuel filter, check for any vacuum leaks, a for the electrical problem, what does not work when the fuse blows?
Mark (mhpautos)
Wednesday, September 29th, 2010 AT 8:14 AM
KEVIN HARBAUGH
MEMBER
I don't know what dosen't work with that fuse that what I was asking about what module this fuse would go to. When putting in a new fuse as soon as the key is turned on it blows, you can still start engine and it runs but you have to pump it up alot to restart
Wednesday, September 29th, 2010 AT 11:45 AM
MECHANIC
I am sure that the running issue is carby / tune related, get this sorted first and then we can work on the electrical problem.
