1981 Other Ford Models engine runs rough
1981 FORD
WRKSUKS
Engine Performance problem
1981 Other Ford Models 6 cyl Two Wheel Drive Automatic
I have an '81 Ford F100 with a 300 6cyl. Yesterday it started missing and otherwise running very rough at idle and driving speeds. I have recently changed the plugs and wires, distributor cap and rotor, performed oil change, etc. It was running fine after all that work. I checked the plugs and they were gapped correctly but fouled after only two weeks in operation. I am getting spark at the plug wires and I tried blocking the egr valve with no effect. Not sure where else to look, again the truck was running beautifully and started acting up while I was driving it.
Mar 27, 2009 at 3:34 AM
BILLYMAC
  • 2,204 POSTS
sounds like ignition control module on fender
Mar 30, 2009 at 8:46 AM
CHRIS_FAULKNER
  • 5 POSTS
[quote:de5d59fcdd="billymac"]sounds like ignition control module on fender[/quote:de5d59fcdd]
Possibility.. $10 part.. also check u'r ignition coil next to the distributor, it may be failing.
Feb 11, 2010 at 4:20 PM
