1980 Other Ford Models
1980 FORD
DAMM
Engine Mechanical problem
1980 Other Ford Models 4 cyl Two Wheel Drive Manual
truck turns but wont start...i think no fire coming from coil?????
Sep 17, 2009 at 5:46 PM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sep 17, 2009 at 6:06 PM
