1980 Other Ford Models
DAMM
  • 1980 FORD
Engine Mechanical problem
1980 Other Ford Models 4 cyl Two Wheel Drive Manual
truck turns but wont start.I think no fire coming from coil?
Friday, September 18th, 2009 AT 12:46 AM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, September 18th, 2009 AT 1:06 AM
