1977 Other Ford Models Assembly sequence(order) of parts ont
1977 FORD
15,300 MILES • V8 • 2WD • AUTOMATIC
JKM1013
I have a set of spindles for front disc brakes for a 1977 Ford Maverick. Starting with a bare spindle, what parts are assembled onto the spindle shaft first?There is a foam type seal, a splash shield, and what looks like a triangular shaped retainer piece with a center hole to fit over spindle shaft. I do not know what goes onto the spindle shaft first before the rotor. I got these parts disassembled and I want to be sure I have all I need before assembling them. Thanks, your help would be greatly appreciated. This is for a 1977 Ford Maverick which would be the same as a 75-80 Ford Granada.
Feb 17, 2008 at 12:07 AM
MERLIN2021
  • 17,250 POSTS
If memory serves, it's the backing plate , foam, then the triangular piece.
Feb 17, 2008 at 12:39 AM
