1968 Other Ford Models Freeze plugs
1968 FORD
DI PAINT
1968 Other Ford Models 6 cyl Two Wheel Drive Manual
I 'm working on a 1968 Ford F-100 that has set for years!!I finally got it running ,went to put water in & it ran out the back !!The pu. has set in the same spot! I looked under & found a Freeze Plug!! Can't find where it goes!! It is fhe 240 cu. 6cyl. can anybody HELP
Mar 30, 2009 at 8:36 AM
BILLYMAC
  • 2,204 POSTS
at the rear of the cyl head in the senter you can,t see it but you can feel it
Mar 30, 2009 at 8:41 AM
