1965 Other Ford Models brake drum
1965 FORD
65,000 MILES • V8 • 2WD • MANUAL
EF5TRISTER
How do I remove the brake drum on my 65' ford f600? I have the left rear off already. that side is the usual set up. it has a big wheel nut that you hit off with a chisel. but the right side is completely different looking. can you help??
Nov 20, 2009 at 7:58 AM
HMAC300
  • 48,601 POSTS
that side should be the same, it probably has the locking washer bent over thenut.
Dec 26, 2009 at 1:58 AM
