1961 Other Ford Models starting problems
1961 FORD
GUY580
1961 Other Ford Models V8
I have a 1956 f600 single axle truck. It starts but won't stay running with key in the on position. The switch tested good, the generator tests good, the voltage regulator was replaced. Any suggestions?
Dec 13, 2009 at 12:21 PM
  • 31,937 POSTS
Hi there, jump 12V to the + terminal on the coil, start the engine,as normal, if it runs ok, the problem is in the ignition loom.
mark (mhpautos)
Dec 13, 2009 at 7:41 PM
GUY580
Thanks mhpautos. There is a resistor ahead of the coil. Do I jumper right to the coil or to the resistor?
Dec 14, 2009 at 12:03 AM
  • 31,937 POSTS
Jump it at the coil, if it runs fine, i would be checking the ballast resistor next, as it well may be a faulty resistor.
Mark
Dec 14, 2009 at 7:20 AM
