1994 Ford Mustang Mid-RPM Stutter
Suggested Repair
Confirm the cracked head was properly repaired and that the fuel tank and fuel system were thoroughly flushed after detergent contamination. The catalytic converter may be ruined; tap it with a rubber mallet and listen for a rattle.
Conversation Summary
A 1994 Ford Mustang V6 overheated after a water-pump failure and cracked a head. Laundry detergent was later put in the fuel tank, and the engine still runs poorly after a rebuild and replacement of many sensors and filters. It may stall or surge at startup and stutter around 2000-3000 RPM until shifted to neutral or revved higher, though it runs better when warm. An expert asked about the head repair and fuel-system flush, and suggested the catalytic converter may be damaged and should be checked for an internal rattle.
