Weird Idleing!
SNOMAN
The car is a 2000 V6 Ford Mustang with 109,000 miles on it. The problem started yesterday when i started my car, it started fine but as it tried to idle it almost seemed as if it wanted to die. It went to about 500 rpms and then after a few moments it ideled fine. Then i would shut it off and then start it immediatlely afterwards and it would idle fine. Then i would wait I say 5 minutes and start it again and would act as if it was going to die again. I have no idea what the problem may be.
Nov 13, 2007 at 11:43 AM
FISHERMAN
  • 937 POSTS
[quote:b024edebbb="Snoman"]The car is a 2000 V6 Ford Mustang with 109,000 miles on it. The problem started yesterday when i started my car, it started fine but as it tried to idle it almost seemed as if it wanted to die. It went to about 500 rpms and then after a few moments it ideled fine. Then i would shut it off and then start it immediatlely afterwards and it would idle fine. Then i would wait I say 5 minutes and start it again and would act as if it was going to die again. I have no idea what the problem may be.[/quote:b024edebbb]
Hello !!
Check the IAC valve (remove it and clean the varnish and gum )
Idle Speed Control Circuit
One of the most common causes of stalling on fuel injected engines is the idle air control (IAC) solenoid or idle speed control (ISC) motor. If the idle speed control device fails to provide the correct idle speed, the engine may die when you slow down or come to a stop. In many cases, the idle control solenoid or motor is gummed up with carbon and fuel varnish deposits.
also check the EGR for carbon build-up ..
The Exhaust Gas Recirculation (EGR) system's purpose is to reduce NOx emissions. As long as the EGR system is functioning properly, it should have no noticeable effect on engine performance. But if the EGR system is leaking or inoperative, it can cause driveability problems, including detonation (knocking or pinging when accelerating or under load), a rough idle, stalling and hard starting.
Let us know to continue with the troubleshooting..
Nov 13, 2007 at 11:46 AM
FISHERMAN
  • 937 POSTS
Electrical components on 3.8:
https://images.2carpros.com/forum/automotive_pictures/576_Mustang_2000_1.jpg
Let us now how are you doing it... Good Luck!
Nov 13, 2007 at 11:55 AM
