water pump/thermostat
ELLIOT28
Just recently my girlfriend's 2000 mustang (80k) has been having heating/cooling issues. first of all, the engine occassionally overheats at a slow rate; inside the car, the heater goes back and forth from cold to hot, but it won't just blow hot air consistently. The thermostat seems to be doing its job; yet the water pump may have a leak because the area surrounding the pump is covered in coolant, but there are no obvious leaks on the pump/gasket. So i'm guessing i need to change the pump and gasket and while i'm at it i'll put in a new thermostat. However, my question is: if the water pump is going bad would that also explain the the heating issue inside the car (whereas the heater blows cold and hot air)? Thank you for the help. Any input is appreciated.
Jan 1, 2007 at 2:14 AM
IDEISLTECH
  • 5 POSTS
more than likely your heater is getiing an air lock do to low coolant level which will cause your heater to go hot than cold. when you replace the pump and stop your leak this problem will go away
Jan 1, 2007 at 5:36 AM
