smell like gas
RYKEM
  • 7 POSTS
my car is a 96 ford mustang with over a 100 and something thousand miles. It is a V6. When it is running it smells like gas. The man that change my oil said it smelled like it from under the hood. so what may my problem be
Feb 20, 2007 at 10:31 AM
NOS
  • 320 POSTS
is the smell coming for exhaust under the hood or is it more of a raw gas smell? does the car run pourly? with not much info to go on. i'am going to have to say you have a bad pressure regulateror you have some bad injector O'rings at the fuel rail.NOS 8)
Feb 20, 2007 at 12:41 PM
MIKE H R
  • 3,094 POSTS
could be a couple of things. fuel leakage, check all connections. charcoal canister in evaporative emissions control system clogged or vapor leaks from evaporatice control system lines.
Feb 20, 2007 at 1:17 PM
