Sluggish engine seems to not be getting gas
DCSTANG65
I have a 1965 Ford Mustang Coupe, 54K miles on a rebuilt 302 V8 that recently had a good amount of work done on it. Rebuilt power steering...reinstalled exhaust (had Purple Hornies)...tune up...among others.
Since I got it back, I have had the same problem a few times. I start up the car and it idles roughly for a bit and then seems to steady out. When I drop it into gear (auto transmission) and put on the gas, it starts and stops and acts really sluggish. I put on the gas at all and it either lurches or outright stalls.
I have had the jets on the carb adjusted twice. It does have a non-stock air filter on it. I did find that the butterfly valve on the top of the carb was sticking and adjusted a pin to allow it to move freely.
I'm at a loss...as my option at this point is to take it back into the shop for more exploratory surgery.
Any help will be appreciated. Thanks.
Dave
Sep 24, 2007 at 2:52 PM
  • 75,988 POSTS
Check the distributor contact point dwell angle or its gap to include the condenser
When the last time you gave it a major tune-up?
Sep 24, 2007 at 10:23 PM
DCSTANG65
Last major tune-up was about a month ago.
This has been a sporadic issue. Mechanic said it could be the jet adjustment on the carb.
[quote:90c37301c5="rasmataz"]Check the distributor contact point dwell angle or its gap to include the condenser
When the last time you gave it a major tune-up?[/quote:90c37301c5]
Sep 26, 2007 at 3:25 AM
