1994 Ford Mustang Dies, P0320
JENBO1369
I have a 1994 Ford Mustang 3.6L. It will drive perfectly fine sometimes and then other times it will die in the middle of the street. It dies even at highway speeds. The last time I drove it I was on the highway going about 60MPH and it died. I tried popping the clutch and it started to sputter as if it were starting to get power again and then it died. When it starts to die it stutters/bucks as if someone were driving that doesn't know how to drive a manual. After that it wouldn't even crank back up. Sometimes it will crank back up and run fine, but at other times it just dies. I have replaced all of the following: fuel pump with entire assembly & filter, EGR valve, TPS, Crankshaft position sensor, ignition wires, coil pack, fuel pressure regulator, mass air flow sensor, differential feedback pressure regulator, PCV valve, battery & terminals/wires, spark plugs, air filter, radiator flush and fill, idle air control valve appears to be new(i just bought this car last year).
After we replace each thing it will crank and run for a few minutes and then it quits again. Then we pull up the code P0320 on the OBDII. I don't understand what this code is saying. Can someone explain it in lamens-terms or tell me what may be going on with my car? thanks
Jun 25, 2006 at 10:44 AM
SHAY
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
this is the closest I've come to finding a description for the code hope it helps a little
P0320 - Ignition Engine Speed Input Circuit Malfunction The ignition engine speed sensor input signal to PCM is continuously monitored. The test fails when the signal indicates that two successive erratic profile ignition pickup (PIP) pulses have occurred. Loose wires/connectors.
Arcing secondary ignition components (coil, wires and plugs)
On board transmitter (2-way radio)
The DTC indicates that two successive erratic PIP pulses occurred.
Jun 26, 2006 at 7:42 AM
LSUSSEL
  • 252 POSTS
The engine code you provided could be any of the below possible causes.
Low battery voltage.
Open/Shorted circuits.
Damaged distributor cap, rotor, plugs or plug wires.
Damaged coil, ICM or PCM.
Hope this helps.
Jul 1, 2006 at 10:00 AM
Suggested Repair
Treat P0320 as an ignition engine-speed (PIP) input fault. Inspect wiring and connectors for looseness, opens, or shorts; check for low battery voltage and arcing secondary ignition parts; and consider a faulty ignition control module or PCM if the circuit checks out.
Conversation Summary
The owner of a 1994 Ford Mustang reports intermittent stalling, including at highway speed, followed by no-crank or restart issues and code P0320 after many ignition and fuel parts were replaced. Replies explain the code as erratic profile ignition pickup pulses and list loose connections, circuit faults, ignition components, the ICM, and the PCM as possible causes.
