Mustang Won't Start After Cleaning Engine Bay
REDNECK SAMURAI
1999 Mustang GT, 5-sp, 91,000 miles.
Hello, and thank you in advance for any help you can offer. I made the mistake of cleaning my engine bay Saturday with an air wand spraying a mixture of Simple Green and water. Although I was careful to stay away from the alternator and electronics, the car will not start. I disconnected the battery to let the computer reset. After I hook up the battery, there is power for the headlights, interior lights, horn, hazards, door locks. Once I press the clutch and try to start the car, I lose all power. No clicking, pumping or other noises. In addition, the previously mentioned accessories will not come back on unless I disconnect the battery and let sit for several hours. The battery checked out good. All fuses under the dash and in the engine bay are good. Battery terminals are clean from all corrosion. No water in the first COP I pulled. Relay in the trunk was not tripped. Grounds to the body are intact. I'm wondering if it's a relay or the computer. Given these symptoms, will jump starting by popping the clutch work? Thanks again.
Jul 10, 2007 at 12:29 AM
MISTERMUSTANG
  • 20 POSTS
Check all the Fuses under the hood one for the starting circuit could have shorted during spraying? I am also an ametuer but that would be the first thing i checked after that check for voltage to starter buy a haynes manual its alot of help and it has schematics and other helpful things
:D hope that helps alittle
Sep 15, 2007 at 4:42 AM
