Mustang power window resetting issue.. (grounding?)
SINNIEBUNNIE
I am having an electrical problem ( 2002 v6 mustang 61k miles auto).
I think something is grounding out the wires for my power windows which then makes
the breaker reset over and over. The windows would work fine after i replug in the fuse and then randomly from an hour to the next day start resetting.
I know for a fact it is my power windows.
When the breaker resets the clock and lights click and flash with each
reset. This continues to happen until i pull the breaker out. Without the
breaker in place everything works just fine except my windows.
Any advise? My windows are stuck down at the moment. I let the car cool for an hour and tried to plug it back in but it just keeps resetting. This use to work in the past but now it doesn't. :cry:
May 16, 2007 at 8:42 AM
AUTOPOP
  • 49 POSTS
Which window is down?
Should pull both driver/passenger window control switches out and reconnect circuit breaker to see if it still resetting or not.
Let us know what you find out!
May 18, 2007 at 7:35 AM
