Mustang fuse problem!
KHCHAUVIN
I have a 1995 Ford Mustang GT, v8,automatic over 100,000 miles. I have had the transmission rebuilt and the odometer does not work since then. I have a fuse that keeps blowing, it controls the speedometer, clock, radio, and inside light that i know of. Can you tell me what i should do to fix this? :D
Sep 15, 2007 at 10:23 AM
MISTERMUSTANG
  • 20 POSTS
yes take it back and tell that a hole you had rebuilding it to fix it but if you cant start at the source the only logical place to look would be what you have had done last right b4 the prob started crawl under there and look for burnt wires loose hanging wires anything out of the ordinary then if you dont see anything start looking behind the dash pull the radio out look back in there when a fuse blows its because there is a short in the circuit either to Ground or a turn to turn short there is only 3 electrical problems one could ever run into thats opens shorts and grounds so its pretty simple if you know a little more about electricity take a look in a book it will blow your mind :D thats a good start anyway pm me if you need more help
Sep 16, 2007 at 5:56 AM
