Mustang Blown EEC Fuse
TURTLE4.6
I have a 1998 Mustang Gt with 87,000 miles that died in traffic with no warning. Flashing anti-theft with a crank no-start (PATS can't communicate with EEC). The EEC fuse blows immediately after the key turns to the ON position. Short is still present after EEC is disconnected. Short disappears when the Constant Control Relay Module is disconnected so I put a new one in but the short is still there. A mechanic has spent hours going over the car and has found no bare wires anywhere. Mechanic has given up. Any ideas would be greatly appreciated. I am about ready to scrap this car because I have already spent hours of head scratching and hundreds of dollars in the garage trying to have it fixed.
Nov 23, 2007 at 1:07 PM
  • 75,988 POSTS
Give me a good description of this vehicle and give me everything I need to know.
Could be the alternator not putting out because of a bad regulator/wiring or a battery that is not taking the charge.
Nov 23, 2007 at 1:29 PM
ERNIESUSEDAUTOPARTS
2003 ford taurus 3.0 u engine 94000 miles battery light doesn't come on and the battery will get so low the engine will die can take the cable off the battery and the engine will die can you help me thank you
Nov 23, 2007 at 1:38 PM
