Manual Transmission problem
SHADOWDUET
I have a 1999 mustang standard 3.8 v6 with manual transmission has 80k miles on it. it doesnt happen all the time but when i try and put it into reverse it will grind. im told that my reverse synchronizer might be going bad if so how would i fix that and how much would it cost to fix?
Sep 3, 2007 at 9:40 AM
RICEINATOR
hi,
I have a 1987 5.0 that does the same thing. I really don't worry about it. What I do is; beofre I put it into reverse,I put it into 4th gear for like 2 seconds then put it in reverse. this should stop the grinding.
Sep 6, 2007 at 3:32 PM
