Ford Mustang GT convertible 2005 brake lights
2005 FORD MUSTANG
CLAULAU
on my mustang my brake lights are permanent on,with the igniton off, the key out and the brake pedal released.
Ford Mustang 5005 GT convertible 2200 miles.
Can you help me?
Mar 24, 2007 at 11:14 PM
MERLIN2021
  • 17,250 POSTS
On the brake pedal there is a switch, First try just pulling up on the pedal, If that doesn't work replace the switch. It called "stop light switch"!
Mar 25, 2007 at 12:41 AM
CLAULAU
[quote:4183fba460="merlin2021"]On the brake pedal there is a switch, First try just pulling up on the pedal, If that doesn't work replace the switch. It called "stop light switch"![/quote:4183fba460]
It isn't the swich,i put the switch of and the lights are still ligthening.
Is there a relay between the switch and the lights(if there is, can you tell me its location).
Mar 25, 2007 at 1:27 AM
MERLIN2021
  • 17,250 POSTS
Did you change any bulbs recently? Ive seen strange things happen when the wrong types are put in...
Mar 25, 2007 at 1:45 AM
CLAULAU
[quote:aad88cd836="merlin2021"]Did you change any bulbs recently? Ive seen strange things happen when the wrong types are put in...[/quote:aad88cd836]
I didn't change anything....
Mar 25, 2007 at 5:31 AM
MERLIN2021
  • 17,250 POSTS
if you unplugged the switch and the brake lights are still on try pulling the fuse...It seems you have a short. Unplugging the switch will determine that for shure. Do the rest of your lights work correctly?
Mar 25, 2007 at 8:29 AM
