ford 4 speed stuck in 4th gear
80GRIT
I have 1966 ford mustang coupe with a 91 302 that has 95000 miles switched to carburated and a boss 302 4 speed toploader with a centerforce dual friction clutch using the 91 flywheel and its non hydraulic set up, with a short syncro hurst shifter with reverse lock out. This setup worked no problem for a while dont know if its meant to work together but driving it the other day I put it into 4th gear at a low speed and now the shifter refuses to let it out of 4th gear I have noticed a fluid leak on the tranny lately but I dont really think that if the fluid was low it would not let it out of 4th and it seems all the linkages are hooked up maybe a bit looser that they should be but connected, the car still grabs when you let off the clutch pedal and it goes into nuetral when you push in the clutch, basically operating the way the way the pedal should, I have no idea cause Ive never come accross this problem ever if you could help that would be great thanks ed
May 20, 2007 at 9:26 AM
2CARPRO JACK
  • 11,533 POSTS
Are you sure it is just 4th and not stuck in 2 gears at once? My old Toyota stuck in 4th and it was a part that held the synchro that let go leaving me in 4th as well. If not in 2 gears at once, then might have to pull the trans and have it tore down to see what happened
May 21, 2007 at 1:21 AM
80GRIT
if it is in 2 gears how do I get it out?
May 21, 2007 at 4:08 PM
2CARPRO JACK
  • 11,533 POSTS
Force it or remove it and have it taken apart enough to fix it
May 22, 2007 at 1:11 AM
