electric fan
SMOOTHACT
1990 ford mustang 2.3 litre auto. The electric fan is not working when the engine warms up. I pulled the plug on the fan itself and put power to it directly and the fan itself does work. I also checked the fuses under the dash which are also good. Wondering where the problem could lie?
May 11, 2006 at 6:06 AM
WITNESS7
  • 5 POSTS
It has to be your Thermo Fan Switch the electric fan works when it picks up a signal from that switch you can find it located on the side of your radiator i believe it is located on the passenger side it is screwed into your fan... this switch goes bad alot of times in a escort and has to be replaced.. rememember to drain your radiator fluid before you remove this switch and that engine is cold...
Aug 6, 2020 at 3:35 AM
